Imported Item
Imported Item
rack and pinnion is mocked up
Imported Item
Imported Item
driver side is mocked up
Imported Item
Imported Item
boxing plates and super ride crossmember is in
Imported Item
Imported Item
template for 65-66 fastback inner plate the will allow the use of the origional outer vents
Imported Item
Imported Item
here is the coupe -fastback conversion sitting in front of stang-aholics shop. looks prety good dont you think
Imported Item
Imported Item
ron does a lot of these
Imported Item
Imported Item
soon be ready for the new ifs
Imported Item
Imported Item
ron has the spring towers trimed away
Imported Item
Imported Item
tomarrow its off to stang-aholics ,ron is going to instal a pro g front and a 4 link 9" rear end. when it comes back its up on the rotisserie for blasting and epoxy prime
Imported Item
Imported Item
its a fast coupe ,a coupe back, no its a fastback its now a roller
Imported Item
Imported Item
drivers quarter window opening is no more
Imported Item
Imported Item
no more quarter window opening
Imported Item
Imported Item
remember this opening? its were the coupe quarter window used to come through
Imported Item
Imported Item
pass. side inner structure is welded in tied the roof brace to the door post ,the inside is done
Imported Item
Imported Item
had to make the front and back of the vent opening as the new quarters do not come with them
Imported Item
Imported Item
made the inner structure pieces for the pass. side
Imported Item
Imported Item
rear view of the welded body shell inner structure is tomarrows project
Imported Item
Imported Item
the body shell is finnished ,except for grinding the spot welds
Imported Item
Imported Item
the lower rear window panel is welded in and a back glass is set in place, perfect fit
Imported Item
Imported Item
the roof is welded on
Imported Item
Imported Item
the rear roof brace is now welded in place and so is the lower rear window area several hours spent in this area measureing and re measuring as the tail panel and quarters and trunk lid were fit all at the same time.got word that jim smart may want to do an article on this conversion for mustangs monthly magazine
Imported Item
Imported Item
pass side quarter now welded in place ,again only welded at the door jamb and lower rocker area
Imported Item
Imported Item
i prefit the pass side end cap the same as the drivers and welded in the quarter end
Imported Item
Imported Item
pass side door structure and rain gutter now in place, again lots of measureing
horse sence
1966 coupe -fast back conversion
this is a 66 coupe a code,with the help of dynacorn sheet metal
and 67 fast back upper door jamb i am converting the coupe into
a fast back
What an awesome community!
Album information
Album owner
horse sence
Date created
Item count
39
View count
2,927
Comment count
Rating
0.00 star(s) 0 ratings
Album privacy
horse sence
Can view media items
Everyone
Can add media items
Album owner only
