1965 Fastback
Busamike
Rock Hill SC
Hi, I need power steering on my 65. I know this has been done to death probably but could you guys help a new guy out. Ive seen the kits for about a thousand give or take, but I really do not want a divorce over this so... any way to go that is somewhat less expensive?. I can turn a wrench and the Mustang already has the granada discs so what will work? or do I need to bend over and buy the kits.
Thanks. Mike
don't forget the steering box too...
I have the same issue..my stang is uncontrollable without power steering,..too much power and it's impossible to counter steer a rear slide..
I'm going to the rack and pinion route, no way I'm spending that amount of cash on just another steering box conversion
No, the hydraulic lines on an early Mustang go into the control valve. There are no lines on the box. I believe the box is the same for power and manual. The only difference would be the ratio of the box. Are there different ratio boxes?
