Hello...now that i've got my new to me 66 going, I'm working out all the small bugs.
My stop lamps weren't working at all, and a new autozone stop lamp switch fixed that.
problem is, the pass side stop lamp doesn't work. The parking lamps in back work, as does the left and right turn signal, but no stop lamp.
I put a volt meter into the plug and nothing....however I get a solid 12v on the dr side.
I'm looking at the wiring, and there are two wires going into each light. I assume one is for the parking, and the other is for the stop circuit..
which wire is whicH?
It appears that there is a crossover wire going from the dr side to the pass side where it plugs in. I'm assuming my issue has got to be somewhere in that wire.
Any suggestions, or even help figuring out which wires are the stop ones would be appreciated, thanks!
