I'm refreshing my bulbs, diffusers, CV regulator and circuit board in the cluster today. I went to remove the dash pad - which is a simple process; however, the pad is stuck firmly against the windshield. I know I have all the screws removed and I'm assuming that someone may have glued the edge somehow or its purely friction. I've given it a good solid tug but I'm afraid any more will cause damage.
My question: Do I need to completely remove the dash pad to remove the cluster? The pad is loose enough that it lifts and I may have the required clearance. I just want to make sure that I'm not overlooking something else and that I really need to pull the pad out.
