Expired 1990 7 Up Convertible
njoliver
259
Columbus OH
fully built 7 up edition mustang. around 1000 miles on restoration.
chassis:
AJE k member
full length subframe connectors
battle box reinforcement
underbody/ engine bay painted with Por15
suspension:
koni DA shocks
H&R road race spings
eibach sway bars
manual steering rack
maximum Motorsports rear lower control arms
poly front arm bushings
brakes:
cobra brakes in front
GT disk in rear
wilwood adjustable proportion valve
cobra master cylinder/ brake booster
braided front lines & rear to axle line
diff:
Ford racing 3.73
5 lug
new seals, rebuilt
transmissions:
auto swap to rebuilt world class T5
cobra clutch
Ford racing trans mount
engine:
302 .030 over
eagle h rods
srp flat top pistons
crank polished
bottom end studded
ARP fasteners throughout
GT40 top end
Ford "F" cam
new water pump
65mm throttle body
Ford racing oil pump/ oil shaft
Moroso 7 qt road race oil pan.
mini starter
wheels/tires :
bullet black 17 wheels
new summer performance tires.
interior is in real nice shape...the front seats do need reupholstered. everything else is in good shape.
exterior:
needs to be redone. it looks okay but many small dents and 1-2 good size ones ( exterior is all original)
The bad:
speedo gear on transmission side has came loose, speedometer does not work.
the clock spring is broke so steering controls, air bag are inoperative.
I'm sure I'm missing a few things here and there. overall it's a nice mustang.
937-7O7-seven6two4
asking $5,500
