98 GT, ~75k miles. Laser Red, Black leather/Rear Seat Delete, very clean. Mods listed below. Tons more than asking price invested in this car. Car is in the process of completion and has 99% of parts needed to finish. Clean, clear title in hand. Will also consider trades for a running driving vehicle plus cash. Wheels can be bolted to the car to allow it to be moved but will need towed or transported on a trailer. Pics available upon request. Comes with some stock parts as well.
284ci
OEM 4340 Forged Cobra Crank
Manley Forged H-Beam Rods
JE Forged Dish Pistons(9.7-9.8 to 1 cr)
MHS Stage 2 Heads with upgraded valves and springs
MHS Stage 2 PI Nitrous/Blower Cams
Edelbrock Victor Jr Intake
ARP hardware including head studs.
Solid Motor Mounts
Trick Flow Adjustable Crank Gears
Cobra oil pump
7qt canton pan.
Pro. Products SFI Balancer
BBK 75mm TB
6061.com Plenum
C&L Inlet Tube w/K&n
Edelbrock Fuel rails.
Pypes Stainless Long Tubes
Off-Road Mac ProChamber
2 Chamber Flowmasters
Flowmaster Tailpipes
Walbro 255 in tank pump.
Aeromotive regulator
Lentech 4R70W w/MVB
B&M Shifter
3200 Stall Precision Industries Convertor
Motive 4.10s
Speedcal Box
D&D Tubular K-Member
D&D Tubular Control Arms
D&D Front coil-overs
UPR Adjustable LCAs.
Steeda Rear Springs
BBK Boxed Uppers
CC Plates
Power Stop Drilled and Slotted Front and Rear Brakes
Stock 2001 GT wheels
Rear Seat Delete
plate nitrous kit with 15lb bottle.
ZEX TPS Activation Switch
Pillar Gauge Pod with Water temp, oil pressure, and fuel pressure gauges. (Autometer Phantom)
PLX Industries Wideband
SCT XCAL2 with Brenspeed Tunes.
Everything works, AC, Cruise, factory mach stereo
Also have a set of painted black Weld Prostars (15x8 and 15x3.5) with BFG Drag Radials
284ci
Solid Motor Mounts
Cobra oil pump
7qt canton pan.
BBK 75mm TB
6061.com Plenum
Lentech 4R70W w/MVB
B&M Shifter
Motive 4.10s
Speedcal Box
Steeda Rear Springs
BBK Boxed Uppers
CC Plates
Rear Seat Delete
