View: https://www.youtube.com/watch?v=1tVcEytFvbg&feature=youtu.be
2003 Mustang GT Premium Convertible
80k on chassis. 1,000mi on completely redone drivetrain
-Fully built Teksid block
-Mahle forged 16cc dish pistons
-New Manley Cobra rods, cobra crank
-Trick Flow 38cc heads, cams
-Tork Tech kit with ported eaton m112 Blower
-LFP dual pass exchanger
-Accufab Throttle Body & Plenum
-60lb Siemens Deka injectors
-Running a 2.8" pulley @12.5lbs currently
-Every single sensor, coil, gasket, bolt and nut are brand new from Ford under the hood
-Shorty headers to stainless off-road H pipe to full SLP LM2 cat back
-Deleted EGR system, Totally bypassed
-Fully built 3650: 26 spline input shaft all new gears and synchos,
- Adjustable pivot stud, 10.5" ram twin disc clutch,
-Ford Racing Aluminum driveshaft,
-Steeda Tri-Ax.....all trans work done by Hanlon motorsports
-Rear has 31 spline Moser street axles
-Raptor Adjustable Shift light
-Brand new cobra Trac Lock unit, FRPP 3.55's
-Single Aeromotive 340 pump with 40 amp boost a bump
-Running 78% duty cycle at 6500 RPM
-Tuned by performance evolution in Smyrna Delaware.
-Car puts down 523/469 to the rear wheels
-Drivetrain good to 700+.
-SLP line lock.
-Cervini's Cobra R Hood
-Cobra Front Bumper
-Brand New Convertible Top
-Brand New Battery (as in 3 days old)
-DVD player with iPod control, backup camera
-Brand New Smoked Headlights
-New Smoked Taillights with Sequential bulbs
-New Rims/New Tires 555 Nittos in the Rear
Car is in excellent shape and always garage kept. I have well over $20,000 in receipts alone for this build, $12,000 into the motor alone. I have a 2" thick binder with every receipt and pictures of the build. Adult driven, non smoker. Everything works, including the AC which is Ice Cold. Selling the car because I purchased a second home that needs work. No tire kickers, cash only, NO TRADES!! If this ad is still up I still have the car. Located in South Jersey, 08232. $12,500
http://southjersey.craigslist.org/cto/4764460692.html
