Ninosport, your Mustang Exhaust & Performance specialist, carries a big selection of top-quality cold air induction kits for the 2005-07 Mustang GT. The following kits were designed by the manufacturer to increase power significantly without tripping the dreaded Check Eengine Light or needing any special computer tuning.
A growing number of customers want the best of both worlds: power and simplicity of use, and these kits delivery on both counts. Most kits add between 10-20 hp to a stock Mustang GT and improve gas milage to boot.
Order your cold air intake kit today from Ninosport and save 5% by using promotion code StangNet!
AEM Brute Force (Click Here)
- No tuning required!
- Simple bolt-on installation
- Highly polished, show-quality aluminum intake tube
- Includes heat shield for increased performance
- Exclusive Dryflow air filter never needs oiling
- Filter cleaning solution included at no charge
AFE Stage 2 (Click Here)
- OEM-quality specially shaped plastic intake tube
- Includes heat shield with attractive aluminum cover
- Oversized air filter provides maximum air flow
AIRAID (Click Here)
- Massive 4" rubber intake tube for street and race use
- Unique venturi insert allows use of stock computer tune
- Remove venturi insert for off-road use (computer tuning required)
- Includes soft heat shield to prevent scratching paint
Injen Power-Flow (Click Here)
- Solid cast aluminum intake tube with bright finish
- High-flow air filter provides protections and performance
AIRAID (Click Here)
