Repaired mine with 3m spray adhesive, peel back and make sure you use a brush to remove all the old adhesive and foam padding, it will easily come of if you rub it back and forth with a stiff brush. Once all loose material is removed mask any area you want to keep clean for adhesive overspray, then spray both the leather panel and door side, wait until glue is tacky to the touch then start to smooth back into place using a plastic scraper or something else that is flat with a bit of flex, tuck in edge all around and your done. Looks like factory, cost 8 bucks for adhesive.
