89 Mustang Gauge And Electrical Issues
JD2210
Hi everyone. I have been having a lot of electrical issues with my 89 lately and looking for some help. The main thing I am concerned with is that when I turn on my headlights my temp gauge, volt meter, and tach all go crazy, basically the whole dash minus the speedo. I recently replaced the headlight switch and the harness connector as they had got hot and cracked. I also replaced the ignition switch recently as well. I have also gone through all of the grounds in the engine compartment and cleaned etc. Also, I ran a new ground wire directly from the battery neg. to the body and yet my gauges still go crazy when I turn on the headlights, it gets even worse when I turn on the high beams. Are there some grounds hidden under the dash that I am missing, a problem with instrument voltage regulator or anything else? I am at my wits end and will greatly appreciate everyone's input.
edit: I also put a new alternator in thinking that was bad since the volt meter was running low but with the new one the volts fluctuate wildly with the engine RPMs, anywhere from 8 to 16 and the gauge even bounces with the blinkers.
i would need a wiring diagram and the car to determine if you are missing a ground or two, but chances are good that at least one is missing. and it doesnt have to be in the dash wiring either, it can be hidden away somewhere else. for instance on my old F250 i found i had a ground issue when i would turn on my headlights, the temperature gauge would start rising to the overheating parts of the gauge. what was happening was the gauges were supposed to be grounded through the engine block, but there was no real ground between the block and the chassis. you may have a similar issue somewhere.
Missing or bad secondary power ground - see below for more information...
Grounds
Revised 28-Oct-2012 to add signal ground description & possible problems if it is bad
Grounds are important to any electrical system, and especially to computer controlled engines. In an automobile, the ground is the return path for power to get back to the alternator and battery.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. The clue to a bad ground here is that the temp gauge goes up as you add electrical load such as heater, lights and A/C.
Any car that has a 3G or high output current alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects. The 3G has a 130 amp capacity, so you wire the power side with 4 gauge wire. It stands to reason that the ground side handles just as much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery , computer, & extra 3G alternator ground wire as described above in paragraph 2. A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
Correct negative battery ground cable.
56567d1230679358-positive-negative-battery-cable-questions-86-93-mustang-oem-style-ground-cable.gif
3.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally: it comes off the ground pigtail on the battery ground wire. Due to its proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness.
All the grounds listed in items 1,2 & 3 need to bolt to clean, shiny bare metal. A wire brush or some fine sandpaper is the best thing to use to clean the ground connections.
4.) All the sensors have a common separate signal ground. This includes the TPS, ACT, EGR, BAP, & VSS sensors. This ground is inside the computer and connects pin 46 to pins 40 & 60, which are the main computer grounds. If this internal computer ground gets damaged, you won't be able to dump codes and the car will have idle/stall/ performance problems
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground. It is an orange wire with a ring terminal on it. It is located in the fuel injector wiring harness and comes out under the throttle body. It gets connected to a manifold or bolt on back of the cylinder head.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself. The TFI module ground terminates inside the computer.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. Be sure to have the maximum load on a circuit when testing voltage drops across connections. As current across a defective or weak connection, increases so does the voltage drop. A circuit or connection may check out good with no load or minimal load, but show up bad under maximum load conditions. .
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch
100 mV Ground
0 mV to <50 mV Sensor Connections
0.0V bolt together connections
attachment.php
Extra grounds are like the reserve parachute for a sky diver. If the main one fails, there is always your reserve.
The best plan is to have all the grounds meet at one central spot and connect together there. That eliminates any voltage drops from grounds connected at different places. A voltage drop between the computer ground and the alternator power ground will effectively reduce the voltage available to the computer by the amount of the drop.
Reactions: 1 user
Thanks for the replies guys, I just got done changing the main ground from the batt to the timing cover and changed the secondary from back of block to firewall. I also cleaned the other grounds I could find like the one by starter solenoid and headlight grounds by radiator. Unfortunately this hast helped. I did notice that when I mess with the dimmer switch the temp gauge goes up or down accordingly. Could a bad dimmer switch cause these strange issues? Thus car has other issues as well. The battery would drain over night if left hooked up and it also won't start with the key. I found 6 wires underneath by the transmission which appeared to have been chewed threw(car has sat outside for about 5 yrs untouched). These wires plus 2 others all went through a grommet on the drivers side of the transmission tunnel and then tie in with harness under carpet. I spliced all 8 wires under the carpet and ran back through grommet and wired them back up but I can't find where 2 of them went. One connector had 4 wires on both sides of connector, purple, blk/pink, white/pink, and red/blue. The purple and blk/ pink one go to a fitting on the transmission but the white/pink and red/blue were cut on that side of connector and I don't see anywhere they would have went. After changing wires car still doesn't start with key(I have NO power to clutch switch) and gauges are still crazy But at least it seems like the battery is no longer draining. Sorry for long winded post but hopefully added details will help. I'm terrible with electrical problems and these are driving me nuts.
Picture of the grommet under drivers side seat and one of the two connectors under the car that had wires damaged. The connector shown is the one that i don't know where the white/pink and red/blue wires go underneath the car. the other two wires on that connector go to the transmission on drivers side and there only appears to be 2 wires needed at that fitting. The fitting on the transmission has 2 threaded brass studs that the fitting pops onto.
Well, I didn't replace the dimmer switch but I cleaned it up and used some 400 grit sand paper to lightly touch up the contacts. Everything with the dimmer looks fine, but still the same issues. I almost have the dash out, and have found some more grounds along the way. Will clean those up to see if any helps
I got the dash out and heater core replaced, which is why the dash came out. what I found was when I pulled the gauge cluster the electrical connector on the tach side was only partially connected and the speedometer cable pulled right off without releasing the tab. This interior has obviously been pulled apart before. another thing that I noticed was that a ground by the park brake switch, under the center counsel was about ready to fall off. I don't know whether the ground by the park brake or the loose connector on back of gauge cluster was the culprit but all my gauges and lights now work. Now I just have to figure out how to get it to start with a key instead of a screwdriver....
See the troubleshooting section below. Some of the wiring colors in your post match the ones in the starter wiring.
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
I did get the car to start using the key today. Previously I posted about not knowing where 2 wires on the transmission harness were supposed to go. The 2 wires came through the tunnel one white/pink and the other red/green or red/blue... It looks to me like the opposite side of this connector, the white/pink and red/green wires were both red/green. I assume this was a jumper since this is a manual transmission and on an automatic they would have gone to the neutral safety switch. I jumped the new wires that I had strung to replace all the ones that a mouse chewed off and now the car starts fine. If you don't have power at the clutch safety switch this might be a place to check, never know if a mouse was hungry or something got kicked up and tore the wires since it's exposed underneath the car.
