94-95 Gt-gts-cobra-cobra R / Specs / Installs / Pics / How To's / Combo's / Updated 8-21-12
21. Here you go everyone, a Technical/How-to thread index! For FOX Body and SN95's with Ford Fuel Injection 86- 95.
This is to replace the current "Official HOW TO THREAD" with an easy to navigate index of threads and write-ups on some common tasks related to our cars. I stole this idea from Daggar, so I can't take credit for it, but this should be very useful to all the members, new and old. If you come across something that you feel should be added, please shoot a PM to the moderators of this forum to have it added to the list!
This is a mix of FOX 86-93 How To's and 94-95's items.
87-95 Heads, Cam, Intake Install Help - 5spd GT
94-95 Mustang Serpentine Belt Routing - Bullitt95
Cranks OK, but No Start Checklist for Fuel Injected Mustangs - jrichker
Common clutch part numbers and clutch installation write-up - 5spd GT
Cylinder Head Removal & Replacement - jrichker/5spdGT
EEC-IV Trouble codes - quick reference .pdf - StangGT1995
HOW TO: 13" BAER REAR ROTOR UPGRADE - 91LX_5L
How to check piston to valve clearance
How to install headlights and foglights - davis3
How To Install Radiator W/Mishimoto Brackets ****PICS**** - davis3
How to install manual fan switches - CManT1914
How To Install-Sequential Tail Light Kit ***pics*** - davis3
How to install pedestal mount rocker arms
How To Install-Poly Axle Housing Bushings ***Pics*** - davis3
How to paint your dashboard - davis3
How to remove and reinstall your timing cover - Danman765432
How to replace fuel filler tube gasket - davis3
In-tank fuel pump replacement - 5spd GT
Need Seafoam 101: How to use - 94-302-vert/Chythar
Pictorial Guide to Odometer Gear Replacement - Jinx102672
How To Delete The A/C System ***PICS*** - davis3
Surging Idle Checklist - jrichker
22. 1995 Cobra R (Temp Pics)
23. Odometer Gear Replacement with Pictures (Added 1-5-12).
Special thanks to Jinx for detailed write up.
24. Common Question Threads- What size TB, MAF? What gears? Here are threads to help you decide.
Compiled by NikwoaC from the FOX 5.0 Talk Section.
Some of these items carry over to 94-95 vehicles.
Engine Performance
What size throttle body should I use?
http://www.stangnet.com/mustang-forums/818051-90mm-throttle-body-overkill.html
http://www.stangnet.com/mustang-forums/764787-throttle-body.html
http://www.stangnet.com/mustang-forums/747160-quick-q-throttle-body.html
What size/type MAF sensor should I use?
http://www.stangnet.com/mustang-forums/614633-will-maf-sensor-work.html
http://www.stangnet.com/mustang-forums/564052-help-mass-air-meter.html
http://www.stangnet.com/mustang-forums/601156-73-76mm-mass-air-meter.html
How much power can the stock block take?
http://www.stangnet.com/mustang-forums/679536-500rwhp-real-limit.html
http://www.stangnet.com/mustang-forums/735096-2-bolt-strengthening.html
What is the difference in GT40 (tubular)/Cobra/Explorer intakes?
http://www.stangnet.com/mustang-for...orer-gt-40-intake-thread-56k-dont-bother.html
What is the difference in GT40 heads?/What do I need to use GT40-Ps?
http://www.stangnet.com/mustang-forums/581864-quick-gt40p-question.html
What belt size do I need to omit X accessory?
http://www.stangnet.com/mustang-forums/646822-schematic-routing-short-belts.html
http://www.stangnet.com/mustang-forums/780587-how-delete-smog-pump-reroute-belt-302-5-0-mustang.html
http://www.stangnet.com/mustang-forums/728664-what-size-short-belt-combo.html
What are the best "beginning" mods?
http://www.stangnet.com/mustang-forums/813753-noob-5-0-mustangs-buying-one-best-mods-what-look.html
http://www.stangnet.com/mustang-forums/806087-best-foxbody-mods.html
What is better, H-pipe or X-pipe?
http://www.stangnet.com/mustang-forums/803353-x-pipe-sound.html
http://www.stangnet.com/mustang-forums/789453-catted-h-x-pipe-offers-best-ground-clearance.html
http://www.stangnet.com/mustang-forums/713247-difference-between-h-x-pipe.html
http://www.stangnet.com/mustang-forums/819607-h-pipe-have-deeper-sound.html
What muffler/cat-back sounds/performs the best?
http://www.stangnet.com/mustang-forums/732868-bassani-magnaflow.html
http://www.stangnet.com/mustang-forums/734790-loudmouth-1-vs-2-a.html
http://www.stangnet.com/mustang-forums/727642-hmmm-what-mufflers-get.html
http://www.stangnet.com/mustang-forums/726096-pypes-exhaust.html
http://www.stangnet.com/mustang-forums/760790-flowmaster-vs-dynomax.html
http://www.stangnet.com/mustang-forums/766444-exhaust-clip-mega-thread.html
http://www.stangnet.com/mustang-forums/778632-idle-rev-clips-post-em-up.html
EFI Mysteries and Electronics
How do I set my TPS voltage? Does it really need to be right at 0.99999999V?
http://www.stangnet.com/mustang-forums/825424-adjusting-your-tps-0-98v-not-necessary.html
What injector size do I need?/Will these injectors work with my MAF?
http://www.stangnet.com/mustang-forums/848192-what-injectors-do-i-need-my-build.html
What do I need and how do I install a 130A alternator?
http://www.stangnet.com/mustang-forums/646825-3g-alternator-install-how.html
Handling and Suspension
I want to lower my car, what springs/shocks/struts should I use?
http://www.stangnet.com/mustang-forums/678593-lowering-springs.html
http://www.stangnet.com/mustang-forums/500680-frpp-lowering-springs-any-opinions.html
http://www.stangnet.com/mustang-forums/826771-should-i-lower-my-car-thinking-about-b-springs.html
Will I have wheel hop if I remove the quad shocks?
http://www.stangnet.com/mustang-forums/778532-quad-shock-debate.html
What upper/lower control arms should I use?
http://www.stangnet.com/mustang-forums/803791-whats-best-choice-upper-lower-control-arms.html
http://www.stangnet.com/mustang-forums/812566-so-why-those-summit-control-arms-were-so-cheap.html
What about general suspension/chassis information?
http://www.stangnet.com/mustang-forums/758792-best-k-member-stock-arm-springs.html
http://www.stangnet.com/mustang-forums/805996-aftermarket-k-member.html
http://www.stangnet.com/mustang-forums/789304-can-i-make-5-0-handle.html
Wheels and Tires
How do I convert to 5 lug?
http://www.stangnet.com/mustang-for...ug-5-lug-brake-conversion-upgrade-thread.html
How big of a wheel/tire can I use?
http://www.stangnet.com/mustang-forums/716968-wheel-backspacing-offset.html
Appearance/ Body
Where are all the nice Foxes?
http://www.stangnet.com/mustang-forums/539102-thread-nicest-foxes.html
http://www.stangnet.com/mustang-forums/759233-fotm-voting-rules-regulations-fotm-archives.html
Should I convert my 4-eye to an Aero nose car?
http://www.stangnet.com/mustang-forums/771054-before-you-butcher-4-eye-56k-beware.html
Drivetrain
What is my gear ratio?/What gear ratio should I use?
http://www.stangnet.com/mustang-forums/544202-what-gear-ratio-do-i-have.html
http://www.stangnet.com/mustang-forums/598843-3-08s-3-73s-how-big-difference.html
http://www.stangnet.com/mustang-forums/403409-guys-who-went-2-73s-4-10s-lets-hear-your-opinions.html
http://www.stangnet.com/mustang-forums/549477-aods-3-73-gears.html
http://www.stangnet.com/mustang-forums/813795-rear-end-gears-3-55s-3-73s.html
What speedo gear do I need?
http://www.stangnet.com/mustang-forums/830254-3-73-rear-end-speedo-gear.html
How strong is the T5?
http://www.stangnet.com/mustang-forums/815587-school-me-5-spds.html
What is the best short throw shifter?
http://www.stangnet.com/mustang-forums/829314-tri-ax-vs-pro-5-0-vs-mgw-t5.html
How strong is the 8.8 rear end?
http://www.stangnet.com/mustang-forums/731024-when-stronger-axles-needed.html
How do I swap from an auto to a manual transmission?
http://www.stangnet.com/mustang-forums/811276-t5-swap-questions.html
General Maintenance and Repair
How do I replace my heater core?
http://www.stangnet.com/mustang-forums/646250-replacing-heater-core.html
http://www.stangnet.com/mustang-forums/680267-heater-core-comparison-question.html
Random and Etc.
Is my car a Cobra?
http://www.stangnet.com/mustang-forums/838277-my-car-cobra-definitive-answer.html
http://www.stangnet.com/mustang-forums/838138-do-i-have-real-cobra.html
Where can I find production numbers for my car?
http://www.stangnet.com/mustang-forums/530421-official-fox-body-production-number-thread.html
Is there a place where I can find information on other member's cars, how they built them, and how they perform?
http://www.stangnet.com/mustang-forums/761371-official-progress-threads-thread.html
http://www.stangnet.com/mustang-forums/677534-dyno-1-4-mile-time-thread.html
Do we have any old archives of general Fox Mustang information?
http://www.stangnet.com/mustang-for...old-5-0-mag-articles-i-need-your-support.html
http://www.stangnet.com/mustang-forums/789387-some-old-mustang-test-videos.html
http://www.stangnet.com/mustang-forums/725558-fox-mustang-trivia-thread.html
Contributors so far:
Me! (NikwoaC)
skunk21
No.11
wythors
25. Stangnet Sponsors & Shops- Need some parts or work done to your Mustang?
Here is a list of Sponsors, Shops, Etc. Click on the Company and it will take you to their webpage.
Click here to enter the Sponsor / Shop Forums on Stangnet. Specials, Promotions and New Products are posted frequently so check back often.
http://www.stangnet.com/mustang-forums/forums/vendor-sponsor-forums.228/
Sponsors
  1. Steeda[@]​
26. Stangnet User Quarter Mile Times - GT / GTS / Cobra.
Power Adder (Blower, Turbo or Nitrous), Any Size Motor
1 lxfiveo 10.01 at 135.95 (T) (310)
2 Don 95Vert 10.70 at 128.70 (T)
3 Redsnk95 10.77 at 127.76 (S) (302)
4 Big Jay 10.83 at 143.50 (S) (347)
5 moneypit94 10.96 at 128.05 (S) (331)
6 BLT2BTU 11.27 at 125.75 (S) (302)
7 2Many 11.23 at 121.60 (N) (302)
8 94speedracer 11.24 at 124.00 (S)
9 steve hanson 11.27 at 125.70 (S)
10 YEAHLOH95 11.31 at 125.53 (S) (302)
11 BIGTONY26 11.37 at 118.01 (N) (302)
12 blackmagic94 11.50 at 124.00 (T) (306)
13 revhead347 11.50 at 118.00 (N) (347)
14 Dave95GT 11.56 at 124.00 (N) (331)
15 beecha91 11.56 at 121.00 (S) (302)
16 svegt 11.59 at 118.28 (N) (306)
17 slvrsn 11.64 at 119.98 (S) (302)
18 AndrewBodine 11.70 at 119.00 (S) (302)
19 94speedracer 11.71 at 124.00 (S) (327)
20 Bling 11.80 at 124.20 (S) (306)
21 94 gtr 11.87 at 116.00 (S) (302)
22 DanG 11.90 at 123.00 (S) (302)
23 rel3rd 11.92 at 116.00 (N) (302)
24 94TURBO5 0 12.09 at 117.63 (T) (302)
25 jwalker 12.07 at 117.86 (N) (302)
26 GTWayne 12.24 at 112.50 (S)
27 slvrbullit302 12.38 at 110.00 (N) (302)
28 RACEME 12.42 at 109.00 (N)
29 BlueOvalStangGT 12.79 at 112.70 (S) (302)
30 VibrantRedGT 12.81 at 116.53 (S) (302)
31 AUcobra94 12.82 at 111.55 (N) (302)
32 deadly97snake 12.90 at 108.38 (N) (302)
33 SVTCobra306 12.91 at 112.73 (N) (306)
34 94gts 12.91 at 110.68 (N) (302)
35 Houston94vert 12.98 at 111.01 (N) (302)
36 gcomfx.com 13.05 at 106.05 (N) (302)
37 95STANG-GTSC 13.10 at 109.00 (S) (302)
38 blksn955.o 13.10 at 107.00 (N) (302)
39 OINKAodeOINK 13.19 at 105.00 (S) (302)
40 Tarik916 13.40 at 104.00 (N) (302)
(S)-Supercharger, (N)-Nitrous, (T)-Turbo
Naturally Aspirated
1 Killercanary 11.50 at 121mph (331)
2 danchamp 11.57 at 119.60 (410)
3 kck6894 11.32 @ 119.6 (347)
4 Dave95GT 11.99 at 117.00 (331)
5 Badilstang 12.07 at 109.00 (331)
6 moneypit94 12.25 at 112.23 (331)
7 svegt 12.37 at 111.09 (306)
8 porchstang 12.50 at 110.49 (357)
9 twstd50 12.78 at 108.00 (331)
10 Pops Fun 12.91 at 106.59 (347)
11 MadDAWG zr2 13.19 at 102.93 (308)
12 Cobrar77 13.30 at 106.00 (351 Cobra R)
13 Redline_351R 13.48 at 105.33 (351 Cobra R)
14 go-stang5.0 13.70 at 109.21 (331)
Naturally Aspirated Stock 302 Block
1 TMC 11.63 at 118.47
2 Killercanary 12.03 at 112.51
3 ADRENA LYNN 12.26 at 117.00
4 Mook 12.30 at 113.60
5 2Many 12.43 at 108.90
7 Zenboy99 12.45 at 110.8
8 Eric94GTvert 12.47 at 108.98
9 95Snoozer 12.50 at 109.17
10 BIGTONY26 12.66 at 109.75
11 Slopoke 12.68 at 105.70
12 94DreamGT 12.71 at 110.07
13 GTJake 12.74 at 110.00
14 yellow1995Cobra 12.74 at 107.09
15 yellowstang 94 12.78 108.97
16 Slow 5.0 12.84 at 108.14
17 CopMagnet5oh 12.85 at 106.00
18 rel3rd 12.88 at 107.00
19 WhiteDevil 12.94 at 107.25
20 fiveotony 12.94 at 105.48
21 Dan94GT 12.95 at 106.47
22 onebad95 12.96 at 105.09
23 Jackie Chan 12.96 at 104.38
24 gmkillr 12.97 at 106.15
25 94VIRGINIASTANG 12.97 at 108.00
26 juicedstang1 12.98 at 107.23
27 green94droptop 13.05 at 105.28
28 Cobrar77 13.12 at 105.44
29 sldghmr 13.13 at 104.17
30 MattZ281LE 13.19 at 104.28
31 blk306 13.20 at 109.00
32 jetuomi 13.20 at 107.00
33 slvrbullit302 13.32 at 104.00
34 Hairycanary 13.40 at 105.00
35 AUcobra94 13.48 at 102.26
36 mootang 13.49 at 104.00
37 blksn955.o 13.50 at 102.008
38 RACEME 13.54 at 102.00
39 rgs 13.59 at 104.10
40 94Silverbullet 13.60 at 103.51
41 Houston94vert 13.63 at 101.13
42 1105 13.71 at 101.90
43 rustang 13.81 at 98.00
44 Drunk5oh 13.85 at 99.00
45 94GTslow 13.89 at 101.00
46 jtkz13 13.90 at 98.50
47 17yrOldStanger 13.94 at 102.00
48 95GTstang3o2 13.96 at 100.75
49 SVTCobra306 13.96 at 100.60
50 Tarik916 14.00 at 100.50
50 SorsCode 14.00 at 95.65
51 ChromeYellow94 14.02 at 98.00
52 FastGT94 14.10 at 98.00
53 Nobody 14.14 at 99.60
54 5ohhh 14.14 at 98.88
55 stang_gt_1994 14.17 at 98.56
56 viperos 14.19 at 96.66
57 5literstang 14.22 at 96.00
58 Black Stampede 14.27 at 96.55
59 Fordman302 14.31 at 97.80
60 95tealGT 14.33 at 97.03
61 roached1 14.33 at 96.77
62 willys1 14.33 at 96.27
63 Fast94Cobra 14.34 at 97.08
64 Numbles 14.39 at 96.27
65 BLACKKNIGHT94 14.40 at 95.60
66 DaveB 14.41 at 96.23
67 hounddog 14.42 at 96.42
68 mystang94gt 14.47 at 96.04
69 95tang 14.54 at 93.75
70 sipnsyrup 14.54 92.84
71 5LiterFever 14.55 at 94.75
72 Superdust22 14.69 at 95.00
73 Dave14 14.63 at 93.96
74 red95aodevert 14.65 at 92.02
75 unclejackrock 14.68 at 93.95
76 94Vert 14.70 at 95.11
77 mighty_mike 14.70 at 95.05
78 rudeone707 14.73 at 92.00
79 gcomfx.com 14.95 at 91.25
80 94Blue302GT 15.00 at 97.00
81 94gtstang50 15.02 93.98
82 Joe94vert 15.10 at 92.00
83 JJ95GTID 15.12 at 92.23
84 NEEDA5.0 15.56 at 89.00
85 mo_dingo 15.80 at 88.20
86 livenfine 16.55 at 88.00
1/8th Mile Naturally Aspirated
1 2L8ULUZ2 7.84 at 88.70 (306)
2 Slopoke 7.88 at 86.80 (302)
3 slvrbullit302 8.24 at 83.78 (302)
4 mytight95 8.53 at 83.90 (302)
5 Ashentep 8.68 at 81.33 (302)
6 Slo95.0 8.70 at 79.60 (302)
7 grrrrrrr 8.95 at 77.40 (302)
8 mcvey90 8.99 at 76.27 (302)
9 DougNuts 9.00 at 78.00 (302)
10 95WhiteVenom 9.10 at 78.98 (302)
11 E9 95 GT 9.20 at 77.00 (302)
