I copy/pasted the checklist and printed it off. I've been working off of that. Car has ran decent for the last few days I have had it, but Tuesday evening the eng lost all power and it stopped running.
Stock 94 Cobra, has MSD coil and dist. cap/wires. OEM everything else.
Here is where I am at.
There are acorns under the intake, like a squirrel has been living under there and lots of wires are chewed up.
I found the TFI module blown. One side was split open and had its guts pushed out. Replaced TFI module, car fired up and ran about 1min before the new TFI literally went up in smoke. Looks like the wiring to the PIP sensor is bad, like I have a short in the eng harness somewhere, or the ign coil (a MSD blaster? All red, twice as big as oem coil) is over powering the system?, or there is a bad Hall effect sensor in the distributor?
PIP sensor gets voltage to both sides of the plug, shouldn't it only have voltage to one side?
Can the ign coil over power the system blowing the TFI?
Anyone had a similar experience?
My OEM service manual isnt here yet so I'm kinda guessing on what to do next. I am going to jump the wire from the PIP direct to the TFI to bypass the harness.
