- Sep 18, 2016
- 8
- 0
- 1
My 97 GT with a 5.4L decided not to produce spark last week while driving home from work. I've gone through a list of items to check and replace but the common stuff seems ok. All electronics in the car are the original 4.6 electronics. I've got the torque app hooked up to it but not anything is obvious from the app.
Here is what I've done so far
1. Verified no spark from either coil
2. Fuel pressure 40psi
3. Replaced crank sensor
4. Measured crank and cam sensor voltage at 0.07 volts while cranking (seems low but is the same for both sensors even after replacing them).
5. Coils are getting 12 volts power.
6. Cleaned cam and crank sensor plugs
7. Removed tuner chip from PCM
8. Tried disconnecting MAF sensor
9. Theft light come on then goes off in 2 seconds after key on.
10. No codes stored in computer
11. Verified tps sensor is working.
12. Replaced relays in main fuse panel
13. Check all fuses under the hood and in the car
14. Connected the torque app but need PIDs for all sensors.
No sure what else to try other than PCM. Any additional ideas before I replace parts?
Also, how can i perform a PCM pinout test to see if the circuits are good...I.e. pinout diagrambor list of PIDs for car.
Thanks.
Thanks.
