Fox Aod To C4 Swap
The only thing i had to buy was a spacer for the drive shaft because its a little short with the C4 in the car...im pretty positive the mount and cross member all fit...
Did you use the c4. Trans mount or the aod because im,using the aod one and it's about a inch away from the crossmember and I've tried turning it around
My cross member i was able to move foward or back a little so i think that helped...i used the AOD trans mount...like i said the only thing i needed was a spacer on the rear to move the driveshaft up a inch or so...that was it...
Hmm my crossmember is a very tight fit and doesn't move back and fourth
