Well I scored an AOD trans out of a 91 Stang today. All I had to do was take it out. I took the drive shaft for the yoke, the trans, the plate between the motor and the trans. Someone had already swiped the wiring harness so I gotta find one of those. What can I get a 28oz flex plate off of for this setup can I use the one off the C6? It will be going behind a 351C. I am going to get the trans gone through, beefed-up and a shift kit installed. Will be purchasing a lokar TV cable. What will be needed to connect the stock shifter (70 mustang w/C6) to the AOD?
Any suggestions for a torque convertor the one I'm using now has about a 3200-3500 stall.
