Back-up Lights
90 Pony GT
Backup lights aren't working, surprise surprise. Automatic transmission with inspection running up in 3 days.:bang: Replaced the back-up light switch, still nothing. Checked the voltage on the back up lights and got 0. Obviously something wrong. I figure the ground is good, because my brake lights work fine (guessing back-up and brake use the same ground). Fuse was checked and good. Only thing i can think of is the actual wire, but just wanted a little feedback before i rip up my carpet chasing wires.:shrug: I should probably check the voltage on the back-up light switch, i'll edit this when i wake up tomorrow morning.
Any help is appreciated.
Sockets were checked and had no voltage getting to them. I think it has to do with my fuse box, the previous owner moved the fuse box and there's a ton of wires at the kick panel that are cut.
I don't have wiring diagrams for 90, but I do have them for an 89, which should help.
PM me your email address and I will send you a complete Ford Factory 89 Mustang electrical diagram set. The zip file is 2.5 MB and is too big to fit through Stangnet's email gateway.
89 Mustang wiring diagrams zip package–
They are in a zip file format to reduce the size of the package. If you don't have Windows 7 or Windows 8, you’ll need WinZip or other Windows archive tool to extract them from the zip file.. See MajorGeeks.Com - MajorGeeks - Download Freeware and Shareware Computer Utilities for a free download.
The diagrams show the location area and the connectors are drawn to the same shape as those in the car.
You will need the Adobe Acrobat viewer which is also a free download – Adobe Acrobat Reader DC Install for all versions - Adobe Reader download - All versions
Reactions: 1 user
The more I look at this wiring diagram the more my head spins..... Gonna go throughout the car from the back toward the front.
0b376e29bee9184356784d28c1d9e641
I'll start from the reverse lights. 140 ( Black/Pink ) is the wire that powers them. ( Grid 98-89)
8abf0c5e8b0fbbed9a6e9371a4f2475b
Runs throughout the car. (Grid 88-78)
c58dd3ce6b6e8ee5e90a63f43bfa087f
Goes to this plug, which i'll get back to in a minute [Plug 140] (On the grid this is 75-D)
d8131a01c2cf156c55dd5031235f0c73
Back-up switch. Which has 140, but also brings in 298 (What brought in the confusion), which connects to the fuse box. (Grid 55-45)
7ead82fe06bdb4cbeb8b9ce50c94763c
Continuation of Grid 55-45
e9bf34e6926047311e75ef4f4fd43641
c764a906955c5bd77f4ea8de4878243a
80b4f96478abac84e097f9c7bbb08283
Couple of pics of Grid 44-34. Confusing as hell..... Mostly confused from where all these 298 came from and where they are going.
9be11781c5fcced913b62bfddb0b8d6c
Last but not least, the last i could find of 140 and 298. I believe that the yellow highlighter section is the [Plug 140] which leads to the reverse light switch.
Purple runs to the other purple switch on the above picture? I see where the 298 wires come from that lead to the instrument cluster. My turn signals work, which is the lime line, so i know that works.
So i singled it down to the navy blue line, which comes from the purple line, and I'd like to think that's where its cut/not working. (Grid 33-23)
Any thoughts? Am I missing something here? Sorry for the long post, and the horrible color coding.
None of the pictures are visible... There is something wrong, because I tried the manual no assist method and they didn't show up for me either. The problem could with be your web host for pictures.
