- May 7, 2012
- 40
- 4
- 18
You guys have helped me out alot the past couple of threads, and havent come across a similar issue so here it goes...
New 302 build, stock bottom end, re ringed and new bearings.
X cam with comp springs
Gt40 heads and intake
Boltons etc..... still N/A
Car has a slight blue haze at idle.....if you give it gas in neutral, when the rpms drop it puffs quite a bit of smoke.
Doesnt burn a whole lot just commuting, but when you beat on it (last night for a good 30 minutes or so, made 5 or 6 runs) and drove it home this morning 250 miles, i lost about 1.2 quarts. Compression is 130-140 across the board.
Thoughts?
Thoughts?
