- Aug 25, 2013
- 2
- 0
- 2
I have a 94 gt with a 306 crate engine with full by ons. Just incase it might help... Anyways, I started to miss on my #8 cylandar I figured it was tht plug since it has gone out two times before. I also pulled the wire from the distributor cap and it ran the exact same as with it connected. So I replaced all my plugs. Still had a miss. My plug wires were also cracking and were all burnt up and arching on to my headers so I figured it was time to replace those too so I got the ford racing 9mm wires replaced them one by one to make sure I didn't mess up the order. Took it for a test run and it's still missing. Googled the firing order and all that good stuff and it all checked out. Everything was set up right. I even got some injector cleaner and filled up my tank to make sure it wasn't a clogged fuel injector. Still missing..... I am using the same type of plugs as I always have autolite 3924s with a .35 gap. I even took off the dist. Cap and cleaned off everything so make sure there was plenty of fresh metal for good spark. I can't get rid of this miss!!! Can someone please help with any ideas or suggestions??? I miss my car... Feels like I have lost half my hp...
