car troubles, HELP please
just means you have a dohc instaed of sohc. or instaed of 95 hp you have 110.....
So twice as many things to go wrong with it.
lick your finger and then wipe it on the timing belt, then get in and turn the car over.....see if the wet spot moves
Okay, I had to use a wet towel but end result was the same. it started drizzeling here during the test (still is) and I am pretty shure it moved. wet spot was gone.
now I am going to get some sleep. Thank you for your help.
I figured it would have COP.....Mitchell says "distributorless" so I guess not.. if you can't get a plug out I've used a bolt shoved into the boot and just set it so that it was about an 1/8 inch away from the engine. The noise throws me too..... almost makes me think the timing belt did jump teeth......
So this is an Escort ZX2 ? They used the same 2.0 on the Focus also.
It's cranking but not turning over...correct? What was that noise you were talking about? Said it sounds like starter gear grinding or something.
Is there anything else unusual you notice while turning ignition? Also,as a rule out test,pull a plug wire + plug.Turn over with plug in wire..out of engine.Ground side of plug to block.check to see if you got spark.
Yes this is the escort ZX2 w/ 2.0 DOHC motor. Don't know about focus, really hope I never get into one of those things.
The starter motor will turn the engine over, Fuel spits out of the shrader valve, and can't check the spark plugs. my socket set does not have deep wells and they are way down there. I have tried before this time to get them out, deep well sockets are the only way it can be done.
While turning ignition on every thing sounds and acts the same as its usual start up routine. These engines shake a bit when turning over and make a real ruckus. all of that is same, just no coming to life after a sec. or 2.
Ohh, there was a plastic box on the + post of battery which was broke many years ago. just + power leads to varouse things the car cant seem to run with out. I have them mashed down by those cheap replacement battery posts u get at auto parts stores. Has worked for years just fine save it gets that build up on em some thing bad.
I keep a battery post cleener and some wrenches with the car just to clean that, and have done it. didn't do much but wake up the electrical systems some, not nearly bad enough to cause the problem.
I don't have a clue what the heck is wrong with this peice of junk.
Well I dont think it skipped timing.If it had ,it would either run horrible or attempt to run and backfire horribly bad.So I wouldn't think it would be that.
Also,the shrader valve on the fuel rail is before the pressure regulator.You may want to have a look at the regulator.Do you have a vacuum pump?
Finally some good news
vacuum pump? pressure reg.? err um Im getting lost here.
I think since we seem to be going around in circles. The easiest thing to do would be to pull the codes on the computer. There are a couple places here in town that rent/loan them or you could buy one.
You don't by chance have an aftermarket alarm installed do you?
Ugh, its not the timing belt and the noise was eaither non existant or irrelevent to the issue at hand IMO.
Sounds like your cam angle sensor went bad. I see it alot on DOHC 4 bangers that just quit while driving and no other symptoms.
where is this cam angle sensor located?
Somewhere behind the timing chain cover. I think its really down low but that may be Kia I am thinking of. Anyway that engine can take a beating if its the same one the Escape came with and I am pretty sure it is. The timing belt is supposed to be replaced every 60,000 miles. That being said I know a guy with an 02 that has 456,000 miles and has broken his timing belt many times with no problems, no interference engine FTMFW! :rock:
Anyway the sensor will be on one of the gears for the timing belt. Its a magnetic pick up sensor. Too bad you reset the ECU cause you could of read the code. It may have thrown one again but there is one there so the best idea is to scan the puter. Dont go throwing parts at it. Buy a scanner from wal mart or Autozone, run the scan then return it :nice:
That was free BTW, you dont even have to tip :p
Cool but you still need to fix your ride. Answer these for me
1. fuel pressure, when you test at the shrader valve, does it just seep out or seem to be under pressure and want to spray everywhere?
2. How much fuel is in the tank,was it empty when it died?
3. When you trying to start it does it seem to turn over faster and easier than normal?
