car troubles, HELP please
Turning over much faster than normal = Camshaft not rotating ..eg.timing belt.
Also,you can test pressure at the shrader valve but pressure will only be greatest for a second since the fuel pump isn't running.
These aren't the same engines that the Escape has.Escape has 2.3L (used to be 2.3..2009 haa new 2.5 engine).The one here is a 2.0.I can check on a Focus for the cam sensor.Actually..He should be looking for the crank sensor.The engine will still run without a cam sensor,but not without the crank sens.
Now if you have an extra person available + a voltmeter,you could unplug the crank sens. and tap the meter onto the sensor.Set meter to mv setting.Have someone crank the motor,and watch for consistant voltage spikes.An analog meter would be good for this.
Finally some good news
vacuum pump? pressure reg.? err um Im getting lost here.
A handheld vacuum pump.Remove vac line from regulator,Attach a vac hose from vac pump to the regulator.Squeeze pump a few times to build vacuum.Now try starting it.Too little vacuum in the regulator and fuel pressure is very low.Which would indicate a faulty reg.
Posted via Mobile Device
See, my first thought was crank angle sensor which is very easy to swap and they are cheap. The problem was I could not find a part number so I figured for must of decided to use the cam angle sensor signal :shrug:
I just did one on a V-6 F series (I know, way different engine) and the truck ran, jast like crap. The sensor was completley broken off. Then I just did a cam angle on a KIA that would not even start with the bad sensor :shrug:
Cool but you still need to fix your ride. Answer these for me
1. fuel pressure, when you test at the shrader valve, does it just seep out or seem to be under pressure and want to spray everywhere?
it sprayed every where.
2. How much fuel is in the tank,was it empty when it died?
about 1/4 left
3. When you trying to start it does it seem to turn over faster and easier than normal?
turning over seems to be normal, though now the battery is getting low so its getting slower.
Looks like its time to go to walmart and get a multimeter and a spark plug. Use the spark plug first to see if you have spark then you'll need to meter to check voltages. As soon as I get my 3 year old to bed I'll send you a wiring diagram.
Gotta check for spark.Get that plastic cover off.Most of them just snap into place with maybe one or two screws holding it.
If you can at least verify the plugs are firing then you got that knocked off.So far..I'm thinking it's one of two different issues.Either your crank sensor bit it..or the coil pack did.Ahh...you got an extra plug wire laying around? (Or borrow a wire from another car that uses the same type of connector).If you do,unplug one of the wires on the coil pack and plug that new wire in.Put a long bolt or socket ext. in the boot and set it close to the block.......crank and have someone check for spark.
#1.it cranks but does not start. battery getting low.
#2.It has fuel pressure, squirted out from shrader valve.
#3. Don't know, only me here maybe dad will help with this.
#4. Don't know, but there should be a code or 2 on there.
