I own a 98 v6 base model, and I have been fixing her up here and there but i came across some P codes that are giving me a bit of trouble and i need emissions done here in GA so im wondering about them...
I have 3 codes...
p0117- Engine Coolant Temp Sensor Low Circuit
P1000 which idk what that means
and P1117... which is ECT sensor intermittent
I JUST replaced the ECT sensor, and after i did that i had 1 code reading (which was the P0117) so i figured there wasnt a good connection so i disconnected, then took out a rubber boot or cover thing that was preventing my connector from fully connecting to the new sensor....
Then i put the code reader on and it reads 4 codes (the p0117 code reads twice on it for some reason) but im wondering if its where i have to drive it around for a while and they will go out or what....
Let me know if you have had this problem and what you did!
Thanks, PS new to the forum.
I have 3 codes...
