I have up for sale a Complete Maximum Motorsports 1990-1993 K-Member Package MMKMP-9 with urethane bushings for sale for $1500+shipping OBO. Everything is brand new and still in the original boxes and packaging. Never been bolted or even test fit nothing to a car. I have since sold the project and have no need for these parts now. I'm in the whole kit for about $1700 plus shipping.
Includes the following:
· MM K-Member- For Modular or Coyote Engine Swap
· MM Front Control arms- Fox Length Non-Offset
· MM Front Coil-Over Conversion kit- Coilovers are set up for the weight of a mod/coyote motor handling set up
· MM Aluminum Steering Rack Bushings
· MM Caster/Camber plates*
· MM Adjustable Tie-Rod Ends
· MM 2-Point K-Member Brace
· Urethane front sway bar bushings
· Sway bar end links (shorter)
For more info please check out the Maximum Motorsports site. Please make sure to check this application against your current build and engine setup. There are no returns so if you want to purchase these parts please check your engine/suspension setup. Feel free to ask any questions. I have a spec sheet to go with it that lists everything you get.
I am located in the Easton,PA 18045 area.
Thanks - John
Thanks - John
