Located in Ellicott City MD, Tremec Z Spec T5 transmission, Factory bellhousing, Center Force Dual Friction clutch, pressure plate and bolts, Factory Ford 157 tooth 50 oz flywheel and bolts, throw out bearing, clutch fork, Steeda Tri Ax shifter, Motorsport cable, quadrant and firewall adjuster, Moroso solid motor mounts and transmission mount, factory transmission cross member, mount, nuts and bolts, clutch fork cover plate and bolt, clutch and brake pedal assy, 2000 miles and 15, 1/4 mile runs, $1500 obo. Also have a Performance Automatic 157 tooth 28oz flexplate, $40 and Motorsport 9mm wire set $20. Transmission and clutch have absolutely zero issues, work perfect, I just installed a C4. Prefer you pick up, I can send pictures of anything.
