I bought a 1979 F-100 Custom short bed.
The truck was crazy fast.
I wanted to take the motor out and put it in my Mach1 that didn't have a motor in it.
Anyway, I noticed how much they had to do to the truck to get this engine to fit.
Anyway, I tried to look up "all" the stamped and casting numbers that are on this block and I'm a little lost.
I know its a Cleveland.?
Just can't figure out what year it is, what the stamped numbers mean and what it came out of.
I took the engine apart to rebuild it for a couple of reasons.
Its been bored .030 over and also has aluminium pistons. Has a 4MA crank and aftermarket Camshaft.
So the casting #'s: D2AE-CA / 1J22
stamped #'s: under the timing plate on passenger side: 1J28C
On rear of block driver's side where the Transmission connects: 2H121516
Under the oil pan, right above the oil filter:
923713/ 11
There's a number ( 7 ) cast in I believe two different places.
I can post pictures of all of these #'s if it would help?
If anyone can help me with this that would be great. Thanks!
By the way, it only has the 2 bolt main caps.
And the intake is a 2bbl with 2V heads. But the casting #'s don't match with the block. Meaning the intake casting numbers are: D1AE-CA -9425-DA / 1J22.
anyway, hope someone can help with any or all of this.
Sent from my SM-N920V using Tapatalk
923713/ 11
