Convertible Top Motor
JD1964
there is enough sticking out to grab on to
3,084
1,382
194
Maryland
93 convertible - The top motor would not run. Relays are clicking and all connections including ground are good. Tap on the motor housing and the the motor starts working. Obviously there is something worn or loose inside of the motor.
Have any of you had this problem? Can I disassemble this thing and have a shot at fixing it of am I looking at buying a whole new motor? Do you have to buy the motor / pump as a unit or can it be bought separately?
Thanks
Just for fyi, just because a relay is clicking does not mean it is functioning properly. You will need to test power lead coming out of relay. Since you are tapping on the motor and it works, I assume that is the problem, but if the relay isn't putting out correct voltage and amperage the motor could have issues operating correctly.
Convertible top motor wiring
Mustang FAQ - Wiring, Engine, Air Bag, ABS Home Page
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
94-95 Mustang wiring diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
In my 28 years experience of owning two fox verts, when the motor stops working and the relays are clicking its time to replace the motor.
Been there a few times and its always been the motor. I've never replaced a top relay.
I have confirmed the condition again. Top wont close > tap on motor housing with wrench > top closes.
Looks like the top motors are $300. Yikes! I was hoping to be able to fix this one. Has anyone ever pulled that off?
At this point you have nothing to lose. Remove the motor and dissemble it. You will probably find a loose wire or broken connection inside the motor. Look closely at the carbon brushes (little blocks of carbon that usually have a wire attached to them) and brush holders. Frequently the brushes will have a small hole in the outside of the motor case. This is to hold the brushes in a retracted position so the you can assemble the motor without damaging the brushes. Once the motor is assembled, you pull out the pin or paper clip and the bushes will pop into position.
Look at the field windings for broken wires or loose connections.
See
View: https://www.youtube.com/watch?v=LAtPHANEfQo
for more help with DC motors.
