is there program or someone knows how to. my time was 10.038 at 72.35 with a 2.304 60'. i ended bending a exhaust valve halfway down the track. oh well P.I. conversion here i come.
i went to the track in dallas called yellow belly. it was a crappy track. worse yet i messed up my stang. i'm in the process of fixing it. hopefully i'll get back out....with a better time.
i'm putting a 98 gt motor in with the pi swap. i'm also eventually putting 4.10 in the rear with a rear end rebuild kit and timing adjuster. i already have longtubes, catted h and catback. i also have underdrive pulleys, cold air intake and superchips 1725 programmer.
also there is no sure way to convert. if you run 9.5@82 using time is useless. MPH has as much to do with it as time. you can't say that 9.5@82 = 14.85. the mhp should be 72-74 for 9.5.
