I have a 2 speed fan controller for an electric fan manufactured by Delta Current Control (DCC), arguably one of the best electric fan controllers on the market. The low speed turns on at 185F, but is adjustable over a wide range of temperatures. High speed turns on 10 degrees higher and disables the low speed circuit.
The controller is a simple install and works great. I've had it installed in my Fox Mustang 5.0 for only about 500 miles and have had zero complaints. Coupled with a good electric fan this works flawlessly. I'm getting rid of it because I'm going back to a stock fan setup to further my restoration project.
It's tricky to take a picture of it in the car. First photo is of the fuse block/power wiring connections. Second photo is the controller itself. You can make out the purple, yellow and red wires coming off the controller. It's mounted underneath my coil cover, along with the mess of other factory wiring.
Located in Colorado Springs, CO/Denver, CO.
$55 shipped
$55 shipped
