Double Check My 5 Lug List.
billison
I like tinted tail
2,579
1,089
184
stl
Couldn't remember if I made a post before or not.
Trying to finish up my shipping for my 5 lug conversion on my 88.
HAVES.
Wheels/tires
94-95 spindles
All 4 calipers with mounts
Factory 94-95 hoses and rear lines.
Passenger side hose adaptor
Valve plug
Adjustable proportioning valve
2 e brake cables for sn95 rears
Cable keeper things
5 lug fox length axles
2-3 adaptor
94/95 master cylinder and booster
rear pads
NEED
Front pads
94 ball joints
Brake fluid
Rear gear fluid
Silicon for the rear cover.
Lug nuts
Missing anything?
I'll be using the 94 brackets to mount the rears
I would get a gasket for the rear cover instead of silicone. And what rear caliper brackets on the rear? Factory ones won't work, you'll need North Racecar units. You'll also probably want a bumpsteer kit.
