Hey everybody I'm new to the forums but not to the mustang world. Any help would be much appreciated.
Ok so I have a 96 gt donor engine with the stock harness computer etc. The engine computer/ harness has been transplanted into a ford ranger along with the mustang dash instrument cluster steering column etc. everything was running perfect and smooth until one day I had the dash loose while it was running and it sorta dropped on the driver side. It stayed running until I cut it off . Fired right back up then died. Turned the key off back on runs for a second or two then dies. This happens every time no matter what. Hooked up a noid light and the injectors are loosing pulse after a couple seconds causing the engine to die. I pulled the dash and didn't see any prob with wires? Any suggestions I'm thinking ccrm or prob computer
