Mustang Led Footwell Kit! Single & Multi Color! Control W/smartphone App!
Diode Dynamics
60
69
St. Louis, Missouri
Ford Mustang Footwell LED Kit
Looking to add a little color to your Mustang's interior? Diode Dynamics' RGBW Multicolor Footwell LED kits are the way to do it! By adding Diode Dynamics' LED strips under your dash, you can add RGBW color-changing ability to your Ford Mustang's footwell area.
This kit is not just RGB, it is RGBW! That means there is an extra integrated LED chip that is specifically white in color, right next to the standard red, green, and blue LEDs. By using an RGBW controller, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
Our Bluetooth Controller will allow you to choose any color under the sun, including True White, directly from your phone! Our mobile app includes a wide variety of features including strobe and fade effects, preset colors, Camera Match, Music Sync, and much more. Our controller will also allow you to adjust the brightness of the LED strips.
Any time you power up your strips, they will default to the last color that was previously selected.
These LED strips in this kit are highly flexible and waterproof. They feature high-density LED chips for brighter output and barrel-style M8 connectors for a secure connection.
Included in the 2-Piece Kit:
  • Two (2) 50cm RGBW SMD30 Strips
  • One (1) wiring harness (4-foot)
  • Two (2) quick splices
  • One (1) red LED toggle switch
  • One (1) DC-to-DT adapter
  • Four (4) zip-ties
  • One (1) 3M outdoor adhesive pad
Included in the 4-Piece Kit:
  • Four (4) 50cm RGBW SMD30 Strips
  • Eight (8) zip-ties
  • Two (2) 3M outdoor adhesive pads
  • Two (2) RGBW M8 extension wires
The 2-piece kit includes everything you need to install LED strips in the front footwell area on both the driver and passenger side of your vehicle. The 4-piece kit includes everything you need to install LED strips in the front and rear footwell areas on both the driver and passenger sides of your vehicle. This kit is very universal in nature and can be tapped into any 12V power source that you would like when installing.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
PM us for the free-shipping code (U.S. forum members only)
Thank you!
Collin O.
Diode Dynamics
Can this be wired to both work with the switch/remote AND turn on while the doors are open? Obviously it would have to be spliced onto something that doesn't require the ignition to be in the 'on' position.
Thanks for your question! By using a SPDT switch instead of the SPST one that comes with the kit, you can essentially do it like this. We recommend this change only by those with electrical experience, since you will need to locate the door or map light wire and run that wire to your new switch. Please see our diagram here- the actual wiring is quite simple. If you would like a SPDT switch instead of a SPST LED switch, please just let us know after checkout. Thanks!
View: https://www.youtube.com/watch?v=hzkV9zznaAY
We're excited to introduce our new RGBW Multicolor LED Strip Kits! These highly flexible, waterproof strips are brighter than our previous RGB strips, and also have an extra white LED chip for a more uniform, pure white color. With our footwell, engine bay, grille, and underglow kits, you can easily add color-changing accents anywhere on your vehicle. Best of all, when paired with our RGBW M8 Bluetooth Controller, you can control them right from your phone!
Check them out in the video above!
