Went to get my 02 GT out of winter storage today. It has a Kenne Bell 1.7L 'screw and there's a BAP wired into the OE fuel pump. The car has had this configuration for many years now with absolutely zero issues.
The car went into storage in late October of '15 and ran like a top. Today after installing the battery I cranked the engine with the throttle floored (as is my usual practice after long-term storage) to circulate a bit of oil, then, after about 5 seconds, I release the throttle and the engine usually starts. This time it sputtered momentarily and just continued to crank. Several cranking attempts produced no firing at all. I pulled the #5 coil off and installed a plug and found a nice hot spark. I then checked the 20A fuel pump fuse (#14) under the hood and it's blown. I replace it with the 20A horn fuse and it immediately blows too.
I checked the wiring at the BAP in the back. There's a 30A fuse between the inertia cutoff switch and the BAP and that's fine (not blown.) The BAP is configured to run all the time (no pressure switch).
Not sure if I should suspect the BAP or the fuel pump or ...? The car was stored in a drive-shed of a farm along with numerous other cars. Perhaps rodents got into the wiring and chewed it, I don't know.
Curious of others' thoughts re what might cause that 20A under-hood fuse to blow with the BAP in there. I've read elsewhere that the 20A #14 fuse is often replaced with a 30A piece but my car's never needed it before.
