Hello Guys and Gals!
I am a lurker and decided to join because I have a problem and wanted to seek out advice.. I have a 2000 GT with 140k miles on it that died while driving it home and it would not start. Was driving just fine and started to miss and stumble. Well flash ahead a few days and last night I had time to look at it. I checked to see if I could hear the fuel pump prime but couldn't.. Fuse is good and checked the inertia switch all fine. Sprayed some cleaner in the intake and tried to start it and it fired up until that burned off. I checked the schrader valve and some fuel came out but nothing else after that so I'm fairly certain either the fuel filter is blocked which I will change first and see if that fixes it but next is the fuel pump, correct? Any other diagnostics I can run?
Thanks in advance!
Thanks in advance!
