Drivetrain Gear Change, Speed Sensor ?
If you have an SCT tuner, then you can go in and change the ratio for the correct gears. If not, depending on the shop that installs the gears, they should have some sort of handheld to adjust the ratio for you. I know our ford dealer in town will re flash the computer for the correct gear size.
Reactions: 1 user
