I'm building a 73 convertible restomod, using the interior and drivetrain from a "90 LX (before you throw stones at me, it is a PA total loss title and yes, the car is bent). Motor ran great 3 years ago before I ripped it out. I put a cam, 24lb injectors, 70MM throttle body and an Explorer manifold on it. Dropped it in the car to check out fit and to see if my wiring works. It ran rough. 3 dead cylinders and a leaking rear seal. No big deal - didn't have it running long enough for the lifters to pump up and I have a new set of roller rockers for it anyway. Sooooo... when I pulled the injectors back out, one pintle cap was completely missing and another looked like mice were eating it. Here's the scary part.... I can't find the parts! Ironically, these two were in the cylinders that were running fine. I did a compression test on all cylinders and all are pulling 155 lbs. I put a shop vac in each intake, exhaust and spark port. Nothing. No debris. Is it possible they got sucked in the cylinder and got spit out through the exhaust? Are the parts melted in the combustion chamber somewhere? Are they hiding in that unknown place where runaway socks from the dryer go? Should I place a picture of them on the side of a milk carton? Anyone have this happen?
