Alright, I'm gettin codes 13, 14, 81, and 42R. I know what each one is, but what do I do about 13 and 14? 42 I should change my o2 sensors, and 81 is due to my smog pump being removed. help me out, thanks.
Code 13 (Key On, Engine Off) ISC did not respond properly (extends to touch throttle then retracts for KOEO) - ISC
Engine running (Key On Engine On)- Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
Code 14 Ignition pickup (PIP) was erratic - Ignition Systems
