8 89llx 5 Year Member Aug 31, 2009 302 5 29 Jul 20, 2014 #1 Jul 20, 2014 #1 I have an 89 GT with edl heads and cobra intake and 410 gears. My question is how much stall should my converter be rated at? 2400--2600--2800--3000
flstang65 10 Year Member Dec 6, 2007 1,484 134 94 SE Georgia Jul 22, 2014 #2 Jul 22, 2014 #2 Cam size? Which heads? and pretty much need every other bit of info about your engine and trans. Where will the majority if the driving take place?
8 89llx 5 Year Member Aug 31, 2009 302 5 29 Jul 24, 2014 #3 Jul 24, 2014 #3 edl heads cobra intake 410 gears, stock cam with 1.7s, aod, very little highway
flstang65 10 Year Member Dec 6, 2007 1,484 134 94 SE Georgia Jul 24, 2014 #4 Jul 24, 2014 #4 If it were me, I would keep it around the 2400-2600 range based off what you have told me.
rbohm Founding Member Apr 12, 2002 6,698 551 204 tucson,az Jul 24, 2014 #5 Jul 24, 2014 #5 flstang65 said: If it were me, I would keep it around the 2400-2600 range based off what you have told me. Click to expand... sounds about right to me also. that should be about 1000 rpm below peak torque.
8 89llx 5 Year Member Aug 31, 2009 302 5 29 Jul 25, 2014 #6 Jul 25, 2014 #6 thanks guys, I too was thinking it needed to come down about 200 -300 rpm The question is would it have a better ET with a 2500 converter?
mikestang63 SN Certified Technician Aug 27, 2012 11,595 9,188 214 In the garage Jul 25, 2014 #7 Jul 25, 2014 #7 89llx said: thanks guys, I too was thinking it needed to come down about 200 -300 rpm The question is would it have a better ET with a 2500 converter? Click to expand... Call the converter manufacturer you are thinking of going with and give them your specs. Try Edge, Dan@silverfox racing, or TCI
