How-to: Setting Garage Door Opener
justinakajuice
138
23
28
I finally read the manual on how to set my garage door opener that's built into the sunvisor. I had just been using the clicker opener until yesterday. Super easy, here we go:
1. Park in or out of your garage.
2. Hold down both your clicker and your visor buttons until your visor light blinks rapidly.
3. Let go of both and try it out. If it doesn't work, repeat.
To be a dick and erase your buddy's codes, hold the first and third buttons down for about ten seconds.
If you have a newer opener with rolling code there is another step. After doing said above, you have to press a button on the garage door motor for learning (usually labeled learn or similar). Then hold the button on the homelink you already learned to the remote until you either see the garage light flash or the door moves. Depends on your garage but that's the general idea.
