Have you done work to the intake recently?This idling problem will be the death of me. It just don't make sense. It idles fine as long as the iac is unpluged. Doesn't smell rich or anything. Anyone have a ideal.
92. 5 speed. Has cats. Was a factory gt. Motor built by pan handle. It's a 331 stroker. Camfield heads. Trick flow intake manifold. 90 mm throttle body. BBK I Belive. Anderson power pipe running to a pro m 80 MAF and filter. BBK long tube headers running to 3 inch off road x pipe.then a cat back borla ex. It has a 373 spindle gear.Went back, aagain, and reread the posts. Need to know; year, stick or auto, cats no cats, was it originally a v8 car, does it have same type of trans. Apparently there will be issues with conversions like mas air from speed density and auto converted to stick. 4 cyl converted to v8 and such. You said it has paperwork with it, that may give some insite.
Never heard it called a spindel gear. When you get the vacuum line issues resoved I think a tune would be in order, but I am not experienced with that level of modifications.92. 5 speed. Has cats. Was a factory gt. Motor built by pan handle. It's a 331 stroker. Camfield heads. Trick flow intake manifold. 90 mm throttle body. BBK I Belive. Anderson power pipe running to a pro m 80 MAF and filter. BBK long tube headers running to 3 inch off road x pipe.then a cat back borla ex. It has a 373 spindle gear.
@Owens 40828 Are you in the Panama City area or did you order the engine from panhandle performance?
Man, I just love it when a plan comes together, even better when it works, I'd like to thank all my fellow 'stange experts on here for helping this mustang owner achieve success because if he whould have relied on me he'd be really f'd up!Update
I had a huge lower intake vaccum leak. New gasket, reset base idle and BOOM......FIXED
Put a 195 thermostat in and ready for winter.
What's a safe temp to run a fox. With the added 195 termo. It's shows about 200. Is that good
