- Jan 13, 2017
- 3
- 0
- 1
Ok guys I need some help. I have a 98 v6 standard shift. I needed to make it an automatic so I took the transmission, transmission lines, radiator, transmission mount, driveshaft, transmission harness, ecm, key chip, and shifter from a 97 and installed it in the 98. The problem I am having now is that the car will not crank and the theft light is flashing. I know the ecm will need to be flashed to remove the theft light but why is the car not trying to crank over? Did I miss something that needs to be swapped over for it to work?
