I'm selling a McCully TFI relocation kit. The kit was used briefly to start my 331, but I just decided to go standalone, so I no longer need this. Everything worked great when removed. Comes with a Motocraft TFI module mounted to the heat sink. Also included is a 'dummy' TFI that has been modified to basically act as a connector at the distributor. I did this because it's more pleasing to look at than 3 loose wires plugging into the bottom of the distributor. There is a small amount of play in the plug at the dummy TFI, so I keep a zip tie on there to ensure it's not going anywhere. The only thing you will need to do is ground the drain wire to the body at the heat sink. $85 shipped for everything. PM or e-mail me if interested. [email protected]
I also have the TFI screw tool available if you need one.
Thanks,
Scott
Thanks,
Scott
