Misc Parts
JEFF B
Banned
166
CORAL SPRINGS, FL
Underdrive Pulleys---Includes Steel UPR Crank Pulley with Bolts, Steeda 10% Overdrive Alternator Pulley and Napa 060798 Serpentine Belt
$50.00
Stock 5.0 Dipstick and Dipstick Tube
$10.00
New Antenna
$4.50
87-93 LX or Coupe Headlight Switch includes Pigtail
$40.00
87-93 Mustang Emergency Switch includes Pigtail
$40.00
E6ZR-7515-AA Clutch Fork
$15.00
M-12259-30 9.5MM Wires Black
$35.00
5.0 Air Charge Temp Sensor---Brand New
$7.00
Ignition Rotors---2 Available
$5.00 Each
E6SF-12A297-A2A Ignition Module
$10.00
E3EF-12A297-A1A Ignition Module
$10.00
Crane Cams PS-91 Ignition Coil
$25.00
Stock 5.0 Ignition Coil
$10.00
Steeda Billet Pedals ONLY 2) Gas Pedal and Dead Pedal
$18.00
Fox Body Outer Tie Rod Ends and Stabilizer Links. Links have Eurethane Bushings and also misc rubber bushings also!
$45.00
94-97 Stock 3 Bolt Fuel Pressure Regulator
$15.00
86-93 Stocl 2 Bolt Fuel Pressure regulator
$15.00
Stock Shifter Ball
$15.00
BBK Cold Air Fender Intake. NOTE! Does not include Pipe from Mass Air to Throttle Body!
$40.00
79-93 Rear Disc Conversion Parts: Crown Victoria Calipers with E-brake Cables, Custom Steeltech Solutions Mounting Brackets.
$125.00
SHIPPING IS EXTRA!
On the U/D pulleys, is that a new belt your including?
Age/condition on the PS91 coil?
Age/condition on the Tie rods and links?
Lastly, age/condition on the Plug wires aswell :)
If you can toss me a pic or 2 with the parts I listed, that would be x-tra cool, I'm interested in all 4.
~Shaun
Shaun
Thanks for the reply. The Belt is not new but very close to it. The Coil has less than 5000 miles on it. The wires are almost brand new. Tie Rods are brand new and the links are used.
Pulleys----- http://i66.photobucket.com/albums/h251/Nitrostangracing/Parts001.jpg
Wires----- http://i66.photobucket.com/albums/h251/Nitrostangracing/Parts007.jpg
Coil----- http://i66.photobucket.com/albums/h251/Nitrostangracing/Parts012.jpg
Tie Rods and Links----- http://i66.photobucket.com/albums/h251/Nitrostangracing/Parts015.jpg
If you are interested, I will take 140.00 shipped for everything. Send me contact information as I can take a Credit Crad over the phone.
Thanks Jeff
Nitrostang Racing
754-368-7336
