Misfire At Low Rpm
I had almost the same thing #3 had a misfire around 2300rpm but at idle it was fine put in a new coil pack and the problem was fine. Maybe your Mass air meter is cracked or there's a leak in the induction system could cause the motor to run ritch and in a result a miss fire or bad spark plugs just an assumption based off experience.
