@jrichker
I was getting some 4 awg wire from my electrician friend at my work and talking about the engine and body grounds on my car and he said that a copper ground wire connected to an aluminum head could cause resistance at a certain temperature and cause the electrical to go haywire. Do you have any thoughts on this?
Got my PiMP and LC-1 compliments of Collin (hoopty50). Also got my Anderson 3.5" NA power pipe, I'm a bit nervous to drill a 4" dia hole in my passenger side fender but I'll be as careful as possible.
Some (slow) progress pictures.
Couple of observations
very nice build
The beer will help making the hole easier
please change that oil filter from the orange can o death
That sucks about the hole you have to drill!!! Your gonna have to line that thing up PERFECTLY!!! I would take measurements of a stock engine bay then cut. You have to much prettyness to mess up!
When I was shooting the picture and could see the fram filter in plain sight I knew I'd get grief from you, lol. I got it only to use for priming the engine and a quick start and warm up then I'll change the oil and filter and replace with either motorcraft or wix.
Thanks for the compliment.
Glad everything came in one piece! was it still packed pretty well?
Yep packed well and contents in same condition as you left them I'm sure.
I'm having a heck of a time with cutting a perfect hole in my apron because these dang hole saw blades keep dulling. I guess they're cheap. I didn't buy them, they were in my dads tool box already. I'll get some good quality ones tomorrow and get my intake installed. Seems like progress is dragging with these small detail items when I only get 1 hour here and there however slowly but surely they'll get done.
Home depot sells a 4" hole saw that attaches to a dril. Just drill a centered pilot hole and have at it. Then dress up the permiter with a dremel or file and put the cut vacuum tube around it.
http://www.homedepot.com/p/Milwaukee-4-in-Bi-Metal-Hole-Saw-49-56-9645/202327761
If it is still fighting you, Harbor Freight sells a cheap body saw for like $20
http://www.harborfreight.com/high-speed-metal-saw-91753.html
