They are reversible if you wire it one way it pushes and the other pulls you want to pull through
I'd have to look . I orderd 2 plugs for the resistor from Amazon , they are the same as the fan motor plugs . Both green with one with a white tracer one with a blue .@TOOLOW91 @MikeH686
i just got my contour fan from Summit and i have no pre-made harness that pkugs in to the fan connection. I see various ways to wire this fan setup however I am not going to use the resistor for low speed, only high. For the fan terminals, which is positive and which is negative?
Thanks!They are reversible if you wire it one way it pushes and the other pulls you want to pull through
This ^^^^They are reversible if you wire it one way it pushes and the other pulls you want to pull through
Side note my nephew has one of those strider bikes ... Kids a daredevil on that thing and he's 3All done (for now) and ready to roll.
*new 3G alternator
*new dual electric contour fans
*FAL 31165 fan controller
*FoMo Co aluminum radiator
*Redline quick lift hood struts
Blue tracer was ground white was power if I am not mistaken to make them puller fans like they should be .
Both were the same gauge wire on the plugs I got .smaller wire is ground and fatter is + for the fan to pull, reverse that for it to push.
hmmmm.. the factory connector wires on the dual contour/cougar fans i've always used from the jy have a fat 10g green and thin 14g black wire.
Used this . It's a standard product replacement plug . I had bought mine new (dorman) so didn't have connectors .
Oh I definitely believe you. I was just showing you the ones I got.You're not gonna make me go to the garage and take a picture of the plug are ya?
Then why not just edit it out, and replace it?My bad Jeff.. Didnt mean to post that emoji... meant this one..
At first I was slightly bothered by it, mostly because they'd just drop their bike next to my car. After a couple close calls and some angry finger wags at them they have figured it out. I don't mind them taking up the space anymore so long as it's all being used and not collecting dust. My 7 y/o son and twin 3 y/o daughters are a blast. Best time ever However the best time ever is about to get down graded a little very soon. About to go through what @mikestang63 and @A5literMan I believe has gone through recently.Looks Great!! Guess you have the same garage kid stuff infestations I use to have, but enjoy them while they're young, doesnt last long...
