So as the title says the damn thing is overcharging am I missing something here what else am I supposed to do
^^^^^^What are you considering overcharging?
I just bought the car. A week into driving I go to my car and nothing no power. Take the battery out to have it charged and run some tests at my job and I accidently tip it over and its dripping everywhere. I will replace the battery and see what happens. The pulley from the old alternator is the same size as the new pa perfoance one. I do have under drive pulleys on it crank and water pump.
Absolutely correct. I wouldn't be concerned if it was as high as 14.7. The op has neglected to tell us what voltage he is seeing using a test meter.I thought 14 volts was within normal range. is that incorrect?
I haven't been able to test it since I had no power at all wen I tried to turn my car on. Once I put a batteryin I will run some testsAbsolutely correct. I wouldn't be concerned if it was as high as 14.7. The op has neglected to tell us what voltage he is seeing using a test meter.
If you haven't been able to test it then how do you know its overcharging? Testing it takes all of 15 seconds. Heck unbolt the alternator and take it to any parts store, most test alternators and starters for freeI haven't been able to test it since I had no power at all wen I tried to turn my car on. Once I put a batteryin I will run some tests
