I have gt40 intake I was told that this mass air will work and it's calibrated with injectorsHiya and welcome aboard.
No... Your computer is not setup to deal with either of those components. That mass air meter you have there will screw up your Mustang's entire world without modification to the EEC itself. In other words: You would require digital tuning at the very least in order to use that mass air meter.
Regardless, neither of these items together or separate, are going to increase the performance on your car. The things that you are trying to modify (in this thread) are both supporting mods. They are things that you would do because of an increase in HP and not for an increase in HP.
The cobra are already calibrated for 24lb injectors the mass air matches it and I know for a fact this intake performs better with 24 injectors a buddy did it but he had a different maf
is just called jegs and try said worse problem I'd have it a rough idle it cannot hurt te computer, they said this mass air is actually to small because of the injectors and my car not being calibrated. But they said it has be done. Thank you or your input but I'm gonna give I a try, the fox computers aren't as sensitive as new tangs. Thanks againThe EEC in your car and the EEC in the Cobra (what was it, a 98 that you said?) have very little in common. What's more is that the EEC in your car contains programming for your mass air meter and injectors.
Now a 93 Cobra is very similar to the A9L or A9P in your car. The difference is that the 93 Cobra EEC was specifically programmed for 24 lb injectors.
The 93 EEC is OBD1 while your 98 Cobra is OBD2.
There aren't many parts that just cross from platform to platform.
I
It worked, just runs a little rich but doesn't cut out or dieGood luck.
