SOLD Nib Aeromotive Stealth 340lph Pump(intank)
Discussion in 'Engine and Power Adder Parts' started by 11B_stang94, Jul 30, 2013.
Thread Status:
  1. 1075617_10152110318897519_419513262_n.jpg 998553_10152108627567519_1681655834_n.jpg 1075617_10152110318897519_419513262_n.jpg 998553_10152108627567519_1681655834_n.jpg 1011393_10152110318732519_972701604_n.jpg Brand new in the box fuel pump. Part number 11140. I ended up with 2 of them. I have the receipt from purchase for warranty that comes with it. It puts out 340lph at 40psi. 150$ IN ATMORE. can ship if needed but you pay shipping. FITS 85-97 mustang except 96-97 cobra
    11140 - 340 Stealth Fuel Pump Center Inlet
    SKU: 11140
    **Center Inlet**
    The Aeromotive 340 Stealth Fuel Pump is a high-output, in-tank, electric fuel pump that fits most popular EFI applications. The Aeromotive 340 is a compact, lightweight pump that bolts into many existing hanger assemblies. (to find your vehicle, see the applications guide below)
    What sets the 340 Stealth Pump apart is its superior flow throughout a wide pressure range. Compared to other popular aftermarket pumps, at 40 psi the 340 boasts more than 340 lph. That’s over 30% more flow. This pump is ideal for applications requiring more flow while retaining the factory lines and mounting provisions available in the Original Equipment (O.E.) configuration. The 340 is also perfect for use as a universal replacement for applications that require more flow to support forced air power adders such as turbo and supercharged applications.
    • P/N 11140
    • Fits most vehicles where popular aftermarket pumps are applicable
    • Center Inlet
    • Includes universal filter sock – may not fit in some applications (see OEM filter
    replacement recommendations)
    • Designed for in-tank use only
    • Can be used in Carbureted or EFI applications
    • Turbine pump mechanism increases durability and can be used in pulse modulated applications.
    P/N 11140 Includes:• Pump
    • Universal Drop Parts Kit (Filter, Wiring Pigtail, Rubber Hose, (2) Clamps, Rubber Grommet)
Thread Status:
