Morning everyone, been lurking around here long enough so I finally joined. I've got a 90 GT that I built and trying to iron out an idle and off idle issue and want some input from everyone. Car is a 347 give or take with 8.5:1 comp, Vortech YSI, 95# injectors with matched Pro-M maf running off a series 4 PMS from AFM, 90MM TB with Foxlake matched Systemax intake and TFS heads with larger valves. EGR is gone and so is evap system (car ran fine with no tune on previous set up with a 302 and S-trim with 30# inj). Has a full msd set up with dizzy and associated items , timing is at 12* btdc and fuel at 44# just to give basics. I can get car to idle well (minor surging) but when I put it in gear and let off the clutch the car wants to buck and die. I went back and did the TPS adjustment and replaced the cleaned the IAC (then replaced it) with no help. Put the car on 30# injectors and stock ecu with matched maf and does the same thing. So any ideas on what it might be or where to start? Codes show for EGR and Evap system but nothing else.
