Power Window Problems
@DO_WORK2913
I have a 2001 Mustang Base model V6
The passenger window isn't wanting to roll down. but if i open up my drivers side door at a 45 degree angle and then press the buttons on both the drivers and passengers side the window will "roll" down or "roll" up. (I usually don't "roll" down a power window :)) .When the drivers door is shut the button on the passengers door pulls power but only when I hit the up button but I cant do that for anything else.
So I do know that the motor, regulator, and buttons kinda work I guess.
Drivers side window works perfectly fine though :)
Inspect the harness in the conduit between the cowl and door. Over time internal wire breaks happen in this location, especially with lots of door cycles. Kinda like when you bend a paper clip back and forth enough times, the metal fatigues and then breaks.
