- Jan 5, 2011
- 113
- 16
- 38
Ok this is probably a simple one for most.
Got this car a while back. Fought some issues and listened to this forum. Did all the checks and NOTHING. So I started replacing parts that could be aged and not up to par.
Fast forward to this morning when I had the idea of the timing not being accurate. So I pulled the #1 plug and verified TDC, distributor rotor was at 12 o'clock and there and that when it gets goofy.
Car has a built motor with a pro street shiny harmonic balancer. Weeks ago when I was verifying the base 10 degree timing I couldn't read anything because the flash of the timing light so I put on a strip of free tape with a line at 10 degrees. And sure enough we were at 10 degrees.
Back to this morning I fire the car up to verify 10 degrees and it's there, pull the timing plug thing and timing is all over the place. So I verified TDC again and marked 0 on my tape. Pulled the tape up to verify if the markings on the balancer were correct... hell no.
So this is what I saw with the timing spout plug w/e pulled. I see 10 degrees on the LEFT SIDE of the 0 marking. That's 10 degrees of timing pulled right? I then adjusted timing to about 10 degrees to the right of the 0. Put the timing plug back in and check computer controlled timing and BAM it's steady as can be. Rev the car and no popping or craziness. Drives WAY smoother. Only thin I didn't do was check vacuum at idle but I will shortly. Only had 5-10 in-lbs originally bouncing all over the place. NO VACUUM LEAKS made damn sure of that days ago.
So to the right of 0 timing is advance correct? Sounds newbie but it never hurts to ask. Thanks guys.
Sent from my iPhone using Tapatalk
